Hi,
I want to encode an avi (xvid) file to wmv with burned in subtitles. So i wrote this avisynth script:
After that i load my avs script into Winavi 7.5 and use the default settings to convert to wmv. After 40 mins or so its done with converting, but then i noticed that the audio gets ot of sync the further the movie plays. At the near end it doesnt even make sense anymore. Does it has todo with Winavi or with my avisynth script?Code:# Created by AVSEdit # FLX 11/19/2006 LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\VSFilter.dll") AviSource("J:\Movies\Golden\cd1.avi") textsub ("J:\Movies\Golden\cd1.srt") AddBorders(0,45,0,45) Lanczos4Resize(320,150)
Regards,
Dennis
Play the script, see if it plays in sync.
Also you would want to move the resize filter to before the borders since I presume you want to resize to 320x150, then pad to 320x240 rather than pad your source by 90 and then resize to 320x150.
Think I explained that in another thread. -
Personally, I wouldn't wipe my a%#e with WinAVI. It is simply an awful piece of software.
That said, there is a good chance your original avi has VBR MP3 audio, which can cause sync issues for converters. Simplest solution is to replace the MP3 audio with uncompressed PCM audio before converting. One method for doing this can be found here -> https://forum.videohelp.com/viewtopic.php?p=1577383#1577383
If you want wmv output, I would use Windows Media Encoder - it's a freebie from Microsoft, and it is a lot better than WinAVI. (Actually, dropping a brick on your foot is less painful that dealing with WinAVI)Read my blog here.
never mind, fixed audio sync problem in avisynth
By spiritgumm in forum Video ConversionReplies: 0Last Post: 16th May 2010, 10:58 -
Seeking audio sync using avisynth trim and selectRange
By Kab09 in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2009, 12:10 -
Audio Sync Problem using WinAvi
By BonnieW88 in forum Video ConversionReplies: 14Last Post: 14th Dec 2007, 11:33 -
WinAVI problem with audio sync
By bennyboy371 in forum Authoring (DVD)Replies: 1Last Post: 3rd Jun 2007, 21:26 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
